h2 wheel's hub opening
Old Feb 21, 2010 | 04:21 PM
2500superram's Avatar
Default h2 wheel's hub opening
i was wondering what everybody's thought's are on opening up the hole for the hub.
even if you don't have a dodge,your input would still be appreciated.
i would like the wheel to still be hub-centric,so the lug's aren't carrying all the weight.i'm not looking to be shearing any stud's and have seen this happen.
i was thinking about using a cylinder bore ridge reamer.i can keep it pretty round for the most part,hopefully
Old Feb 21, 2010 | 06:35 PM
dieseldocter16's Avatar
I dont see a problem doing it there are alot of people running h2 wheels on dodges. However for something like this I would have a machine shop open up the holes so that way they are spot on.
Old Feb 22, 2010 | 10:43 AM
kazairl's Avatar
Ever notice that the stock lugnuts off your dodge have a nice little taper to them? Its interesting to note that the wheels have a corresponding taper. Why do you think that is?
Old Feb 22, 2010 | 06:23 PM
i know the difference between lug nut's.i also know that the stud's are not supposed to support all the weight.i use hub centric ring's on all my aftermarket wheel's and want these h2 wheel's to fit tight on my dodge hub's(just like every auto come's from the factory).no need to have a wheel passing me up while driving down the road
i was mostly wondering what the masses were doing.alot of people are running these on dodge's,figure'd they could give some insight.
i have a table top boring bar,but i've only done motorcycle cylinder's on it.i would need some set-up to hold the rim steady to cut with it though.it just seem's like alot of work for the 2 second's it would take to cut the wheel.
Last edited by 2500superram; Feb 22, 2010 at 06:23 PM. Reason: Automerged Doublepost
Old Feb 22, 2010 | 07:55 PM
A buddy of mine opened his holes up with a die grinder... that didnt work so well. A machine shop is the best option.
Yes, there are a lot of people running H2 wheels
Old Feb 23, 2010 | 12:37 AM
JTProuhet's Avatar
i used a roto zip.. did a pretty good job keeping the hole in a perfect circle.. they fit tighter on my hubs than my factory steel wheels did..
Old Feb 23, 2010 | 06:09 AM
DieselCrawler's Avatar
i used a grinder. wasnt worrkied bout hub centric chit. rims were on the truck for over a year with 35's on them. rock crawled, pulled, everything with them. never broke a stud. hell, my centerlines dont even hit the hub.
Old Feb 23, 2010 | 04:26 PM
kazairl's Avatar
I used a Router on mine. Except for a couple places where I got a little crooked it is a perfectly round hole. Finished it up with some emery Cloth and done. Maybe an hour tops to do all 4. Fits nice and snug.
Old Feb 24, 2010 | 04:44 PM
ok,look's like other people have done different thing's.
i'd like to get it done myself.i haven't done anything with any machinest in my area.i'd just hate to get the wheel's back all chipped up,because the finish on them are nice.
Old May 16, 2010 | 09:41 PM
jrok06's Avatar
Dodge wheels are not hub centric. The rear hub is bigger than the front hubs anyway.
