94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
problems
Old Feb 17, 2010 | 11:11 PM
Branch's Avatar
Default problems
i tore my 97 apart completely to put a longer frame under it and now that i have it back together i have trouble starting it and when it does start it idles very rough and it sounds like its not hittin on all cylinders. it blows heavy clouds of white smoke for about ten minutes after cold start. i think i may have messed something up with the wiring when i tried putting a newer motor in it but im not sure wat. any ideas? and it also wont also hold a charge on the batteries but that may be just because the batteries are bad
Old Feb 17, 2010 | 11:16 PM
ArizonaRedneck's Avatar
charge your batteries overnight and then check them check your alternator to see if its charging and then did you mess with your fuel system at all during the switch and do you know the history of your engine
Old Feb 18, 2010 | 09:04 AM
travisdun's Avatar
I would start with the fuel system.sounds like it is starving for fuel.
Old Feb 19, 2010 | 10:29 AM
Branch's Avatar
ya i did. but even after the smoke clears up it still sounds likes its missing at lower rpms and it backfires when i get on it at all. i was gonna buy a new wiring harness from ford but there price seems a little outrageuos and im not even sure if a new harness would help much
Old Feb 19, 2010 | 07:45 PM
CSIPSD's Avatar
What year motor did you put in it? Did you put a superduty motor in it?
Old Feb 23, 2010 | 01:08 PM
Branch's Avatar
i put an 01 in it but i couldnt make it run so i just put my 97 motor back in it.
Old Feb 23, 2010 | 01:32 PM
CSIPSD's Avatar
The 01 motor has a completely differant wire harness on it. You would have to use the wire harness from your OBS on it. Also the injectors are differant but it should still have run fine.
Old Feb 23, 2010 | 09:51 PM
cummins bronco's Avatar
how much have you driven it?
it does take a good drive to purge all the air out of the oil and fuel system.
after i did the injector o-rings on my powerstroke i just moved the truck around the yard it didn't run right untill i took it for a good drive.
Old Feb 26, 2010 | 09:45 AM
Branch's Avatar
i have all the original wiring on it now. but some of the plugs are corroded and burnt. but it ran fine when i tore it apart. is it possible that i might need a new harness? if so where could i find one cheaper than $800 from ford?
Old Feb 26, 2010 | 03:18 PM
lunk's Avatar
try painless wiring
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Tucker126
Jan 2, 2015 08:09 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
