How Often Should I Change My Rear Gear Oil
Old Feb 17, 2010 | 09:52 PM
bogcjg's Avatar
Default How Often Should I Change My Rear Gear Oil
just wandering
Old Feb 17, 2010 | 10:17 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/chevy-...l-service.html read this and see if it will help you figure out what you need
Old Feb 17, 2010 | 10:20 PM
bogcjg's Avatar
thanx cause i dont think it been changed in a long time i think its time the rear oil may have never been changed the guy i bought my truck of tried to run into the ground you know
Old Feb 18, 2010 | 10:02 PM
Tinman875's Avatar
I am overkill but i do mine every 2 years just cause. 1 suggestion go with a synthetic. It dissapates heat the best.
Old Feb 18, 2010 | 10:54 PM
bogcjg's Avatar
thanx guys i checking it tommaow
Old Feb 19, 2010 | 06:04 AM
Heath's Avatar
Authorized Amsoil Dealer
If you're not sure of the history of it, probably a good idea to change it out. Synthetic highly recommended. It should be good for 25-50k depending on what you put in there.
Old Feb 19, 2010 | 06:34 AM
wildbill's Avatar
Every 30k here. Synthetic 75-90 if a daily driver and some towing or 75-150 severe gear if pulling heavy all the time.
Old Feb 19, 2010 | 06:39 AM
Deezel Stink3r's Avatar
I glued a strong small magnet onto the drain plug with two component glue.
So when I check the level, I also can see metal shavings and wear.
Old Feb 19, 2010 | 03:40 PM
bogcjg's Avatar
thats a good plan
wlofton
11
Jun 26, 2018 08:58 AM
soco
Jul 27, 2015 06:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
J_stout
Feb 21, 2015 11:40 PM
