limited slip?
Old Feb 14, 2010 | 11:34 PM
cfarley0210's Avatar
Default limited slip?
do the 2002 dmax have a limited slip rear axle? does anyone elso have a problem with thers never working? mine never seems to want to get both tires going its usually a one tire smoke show.
Old Feb 15, 2010 | 12:30 PM
BriteWhiteRam's Avatar
the rear end should have the Eaton g-80 locker, some trucks may not have come with it, pull the pan and check it out, if theres no locker it will just be spider gears and ring and pinion, if its the locker there will be a complex locking unit inside the carrier
Old May 11, 2010 | 10:22 AM
abarhydt's Avatar
The locker does have spider gears, but it also has a dog that swings to lock the spider gears, that is why it is so positive and tends to wear out tires.
Old May 11, 2010 | 01:43 PM
Deezel Stink3r's Avatar
The limited slip does wear out really quick.
Thats the main resaon I kicked it out. Replacing it with a 100% manual locker is almost the same work as replacing the clutch parts in the limited.
I love the manual locker, because the automatic can give you real nice surprizes with white knuckels on wet roads.
Sep 15, 2015 07:40 AM
Jul 21, 2015 07:50 AM
Feb 12, 2015 05:40 PM
Feb 12, 2015 03:00 AM
jkidd
Diesel Auto Power
Dec 9, 2014 12:16 PM
