injectors
Old Feb 13, 2010 | 12:34 PM
offroadjim's Avatar
Default injectors
I have 04 6.0 Diesel, Three of the injectors are gone should i replace all 8
Old Feb 14, 2010 | 08:11 PM
ArizonaRedneck's Avatar
yes if you have the money and time you should do all of them but mileage and the reason of why you are changing just three to begin with
Old Feb 14, 2010 | 11:47 PM
dieseldocter16's Avatar
yes always change all the injectors. Our 04 6.0L service truck at work had a dead cylinder, the boss sent it to the dealer and had the bad injector changed and now about a month later guess what . . . another dead cylinder.
Old Feb 15, 2010 | 08:42 AM
Begle1's Avatar
How do you know when the injectors are "bad"? What goes bad in them?
Old Feb 15, 2010 | 09:55 AM
Our truck was throwing a check engine light and when I hooked up the computer I found codes for cylinder 6 misfire. Now it's throwing a code for cylinder 7 misfire. Once the injectors our removed they can be bench tested to see if they're functioning correctly.
Old Apr 29, 2010 | 06:55 PM
cummins96's Avatar
i work for international and yes change all of them at the same time. Also check the push rods and rockers, they are another common thing that goes out on the 6.0 or 365 as international calls them. What happens is the top of the push rod wears out and becomes oval instead of perfectly round and the rocker will come off and cause u to have a dead cylinder too .Just one good thing to check while u are under the valve cover ! The 6.0 injectors have a valve in them that can start to stick going back and forth and that is called stickture and there is a way to check this while the injectors are still in the vehicle . But u would have to go to ford to have this done
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
