06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
Fass
Old Aug 24, 2007 | 06:26 PM
redneckbuckeye's Avatar
Default Fass
What Fass system will be sufficient for my truck 2006 LBZ up to 550 HP. I don't have 550hp but I want to some day( when I get some more money) turn my truck up.
Thanks
Old Aug 24, 2007 | 08:03 PM
rolloffhill's Avatar
No experience in with the fass, but I don't know why it wouldn't. I run a single KD pump.
Old Aug 24, 2007 | 11:38 PM
Wyatt Earp's Avatar
FASS 150/150-3010
that's the part you are looking for. It is good for the kind of HP you want. I would caution running a bone stock truck on that pump though as it might do strange things to the internals on your CP3 injection pump
Old Aug 25, 2007 | 09:30 AM
DangerousDuramax's Avatar
Thanks
If your only going to push to 550 the 95 is plenty. It will actually make your CP3 run much better and you will notice that the engine will idle and run much smoother. If you start pushing 600+ then you will want to look at the 150. One problem you might have is the FPRV might not be able to hold pressure and will set codes. If this happens just get a modified FPRV shim kit from PPE and all will be good.
Old Aug 25, 2007 | 06:48 PM
thanks for the info, just talked to the FASS dudes at scheids today and the 95 is what was recommended.
Old Aug 26, 2007 | 07:02 PM
Sponsors what kind of prices for a 95gal pump with the filters or should I not worry about the filters. PM me some prices need to know what to save up. Thanks
Old Aug 26, 2007 | 09:09 PM
PM Sent
Old Aug 27, 2007 | 06:43 AM
Thanks
Old Aug 27, 2007 | 10:29 AM
I recommend the filters but if your on a limited budjet then get atleast the FASS pump....
Old Aug 27, 2007 | 09:11 PM
CumminsCrazed's Avatar
i ordered and installed my FASS system in June or July and im running a totally stock 24v CTD. I got the 150/95 system and i LOVE it. I was also told that if i ever needed to, i could upgrade my current pump with a different spring and make it into the 150/150 system.
