Idle help
Old Feb 8, 2010 | 05:04 PM
Diesel Mechanic 08's Avatar
Question Idle help
I have a 99 7.3 and want to set the idle up just a lil. Any ideas on how to go about that?
Old Feb 19, 2010 | 10:58 AM
Power7.3's Avatar
I wouldn't mess around with permanently adjusting the idle. Why do you want it to idle faster? To warm up faster? Prevent wetstacking? I wanted to be able to bump my idle up too so I put in an auxiliary idle control module. It goes in under the dash and your pickup should already be pre-wired for it. It's a module they use in ambulances or if you have a PTO you might want one to spin the PTO faster without having to sit in there and hold the throttle down. Also for charging the batteries etc. I wanted one so the engine would stay warm at idle. Mine has a digital RPM display. I have one in my dump truck as well. They are pretty slick. Or, you could order a chip from DP Tuner (or possibly other chip manufacturers I'm not sure). They will burn you a setting that simply bumps your idle up whenever you want it. Your 99' should speed the engine up automatically when it's cold out. Does it?
Old Feb 19, 2010 | 04:12 PM
JMD2005's Avatar
An Aftermarket chip will be your best bet. you can idel up when you need it rather than all the time.
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
Mc Merc
Dec 16, 2014 06:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
