Cummins. Dead pedal?
Old Feb 7, 2010 | 03:55 PM
upINsmokeDiesel's Avatar
Default Cummins. Dead pedal?
So my truck has done this 4 times now....
I will be driving along & I will have my foot on the pedal.
And The RPMs will drop to a idle
Here is some info on my truck..
I have a new vp44 with about 5,000 miles on it
I have FASS fuel
And for what its worth, I just put a new nv4500 5 speed tranny in prob 400 miles ago..
It started right after I put the tranny in, but I doubt it has anything to do with it...
Old Feb 7, 2010 | 04:28 PM
9412Valve's Avatar
Straight from the chat room - Clean the APPS connector.
Old Feb 7, 2010 | 04:29 PM
dennhop's Avatar
cycle the key three times, and see what codes your odometer is reading...
Old Feb 7, 2010 | 04:58 PM
No - use a scanner.
They key on/off trick isnt even worth the effort.
Old Feb 7, 2010 | 05:12 PM
cumminspwrram59's Avatar
did u by anychance change from auto to manual cause they have different tps sensors
Old Feb 7, 2010 | 06:18 PM
dennhop's Avatar
Originally Posted by Dr. Evil
No - use a scanner.
It's worked for me every time I've used it, on my truck and others...if nothing else, it's worth a try.
Old Feb 7, 2010 | 06:21 PM
I guess - it is free. But people just have to be aware that it will not show all the codes that you may have.
Old Feb 8, 2010 | 10:50 AM
It was a manual before. Just the old one went out, so I put a new one in
I will try getting that cleaned.
the key trick didnt work
I will try getting it scanned
Last edited by upINsmokeDiesel; Feb 8, 2010 at 10:50 AM. Reason: Automerged Doublepost
Old Feb 8, 2010 | 12:53 PM
The Key thing never works on a 99.
Old Feb 8, 2010 | 01:19 PM
c-power ram's Avatar
its the pump thats what mine did
