RASB Valve
Old Feb 6, 2010 | 09:14 PM
rwgentry's Avatar
Default RASB Valve
Does anyone know where the RASB valve is on 89 f250 7.3 is. Would it be the cause of the brake pedal going all the way to the floor after holding it. I can push on the brakes and they are good then gradually start to fade?
Old Feb 6, 2010 | 09:54 PM
hillbilly cadi's Avatar
It's on the drivers side frame rail, directly under the brake master cyclinder. I have an 88 f250 that has the same problem. Only my " rear antl lock" light comes on on the dash.
Old Feb 7, 2010 | 09:44 PM
rwgentry's Avatar
do I need to just replace it or can it be cleaned.
Thanks for your help
Old Feb 7, 2010 | 10:10 PM
ArizonaRedneck's Avatar
could be that your master cylinder is going bad but check this outits about the rabs on a ford ranger but it might still be able to help you More Ford Ranger RABS
Old Feb 8, 2010 | 07:07 AM
rwgentry's Avatar
Thank you for the info!
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
