Oil pressure psi.
Old Feb 4, 2010 | 08:13 PM
hillbilly cadi's Avatar
Default Oil pressure psi.
Does anyone know what the idleing psi for oil on a 90 7.3? A couple days ago the oil pressure gauge started acting funny so I replaced the sending unit, and added a mechanical gauge. After the motor warms up and oil pressure on the dash is good, but on the mechanical gauge it drops to 10psi. Drive down the road and the pressure goes up like it should. Is 10psi idling right or is it too low?
Old Feb 4, 2010 | 10:29 PM
DieselCrawler's Avatar
normally 10 lbs per 1000 rpm is minimum.
i know at warm and idle mine has 20. 60 at gov.
Old Feb 4, 2010 | 11:09 PM
Do you think it could be just the pump or something greater? I T'd the mechanical gauge off the sending unit on the turbo which feeds off the oil outlet on the lower drivers side next to the filter. Maybe this is a problem?
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
