Glow plug issues
Old Feb 2, 2010 | 04:29 PM
dolmstead2007's Avatar
Default Glow plug issues
My 88 f350 7.3 is giving me problems starting. Ive replaced the glow plug controller since the original one just flashed the wait to start once and then just clicked. I changed it with a new one and it comes on for maybe 4 seconds. i hit the key and just cranks and cranks. Wont start unless you give it a shot of wd40/ either in the intake. I know that either is bad for them and use very little. I tested the glow plugs and they are good. Im lost and dont know what else to look for? Any help is appreciated. Thanks Dave
Old Feb 2, 2010 | 04:45 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/ford-p...ng-issues.html try this and see if it helps
Old Feb 2, 2010 | 05:16 PM
Okay went out and played with the 88 some more and apparently now i have bad glow plugs 2 middle ones are bad on drivers side and the second one out from the firewall on passenger side. Could this be causing it to cycle a shorter time? Ive gotta save enough money now and replace these.
My 92 isnt starting good either it cranks forever then finally fires. Its got a new controller also and good beur/international plugs. Tested them with the test light trick and all of themmade the bulb light. It doesnt matter if its just but driven 3hrs it still canks forever to start. Anythought on this one?
Ps. I keep both trucks plugged in all any time their at home and it dont make a differeence in starting.
Old Feb 3, 2010 | 05:32 AM
Sycostang67's Avatar
Bad glow plugs can still pass the test light trick. They may have increased resistance but still flow a bit of juice. If the controller only stays on for a short period, it means there is too much resistance. I tested my plugs with a test light, replaced the 2 bad ones and it still started like crap. I replaced the other 6 and now it starts perfectly.
Have you checked for fuel leaks, could be air getting into the system and losing your prime.
Old Feb 7, 2010 | 06:16 PM
agent_123_2000's Avatar
here is a good one for you, take it out and bag it and blow the **** out of it, mine gets hard to start every now and then, i just find a hill and wind er up in 4th gear, blows black and then cleans up, just a thought for you
Old Feb 7, 2010 | 06:51 PM
Now since im not driving it over the road anymore Ft. Wayne to Detroit metro airport everyday im gonna take the 3 inch muffler out and put the straight pipe back in place so it clears the soot more
Metz1234
Mar 3, 2016 10:20 PM
94chevy6.5
Tech Article Submission
Jun 16, 2015 12:45 AM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
