2003 Duramax Starting Problem
Old Feb 1, 2010 | 07:33 PM
Motoxwes's Avatar
Default 2003 Duramax Starting Problem
My 03 Duramax cranks 7 to 8 seconds (longer when cold) before firing, then runs good. I thought maybe crank pos. sensor. Is there an easyway to check and replace this? Any help on this would be great.
Thanks
Old Feb 1, 2010 | 07:45 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and post up your question here for a better response Chevy/GMC Duramax 01-04 LB7 - Diesel Bombers diesel bombers the #1 diesel site around
Old Feb 1, 2010 | 07:53 PM
Motoxwes's Avatar
Hey Thanks
Old Feb 1, 2010 | 07:59 PM
mishkaya's Avatar
Good luck with your issue... Hope it's something simple!
Old Feb 2, 2010 | 03:48 AM
97cummins's Avatar
Old Feb 2, 2010 | 04:02 AM
turbo20psi's Avatar
Welcome to DB.
Old Feb 2, 2010 | 05:10 AM
Jazz's Avatar
Welcome to Diesel Bombers
Old Feb 2, 2010 | 11:34 AM
01trailerpuller's Avatar
Old Feb 2, 2010 | 11:49 AM
K50's Avatar
K50
Check for a leak in fuel pressure somewhere first. Have you tried pumping up at the fuel filter before cranking? Try that and see if it improves cranking time.
And welcome to the site dude.
Old Feb 3, 2010 | 12:43 AM
cfarley0210's Avatar
does it feel like its got power after its running? it might need a fuel filter, when was it changed last?
