need help !#@@$#^@#%
Old Aug 20, 2007 | 07:33 PM
Queeg's Avatar
Default need help !#@@$#^@#%
ok my buddy has a 83 suburban. with the 6.5 diesel in it.
new years he exploded the spider gears in the front diff. and we are having a problem figuring out what front axel he has. one guy says a dana 44 . next guy say somthing else.
stupid thing has sooo much grease i dont know where to look for numbers etc.
anything would help.. thanks
Old Aug 20, 2007 | 07:40 PM
bow2no1's Avatar
i doubt i has a dana 44
if the cover is round it's just a chavy 10 bolt
if it has 6 sides it's probably a dana 60. those usually came one the 1 tons
unless it was swapped it has a 6.2L
Old Aug 20, 2007 | 07:54 PM
scarecrow's Avatar
as long as everything is stock and it is a 1/2 ton it is a corporate 10 bolt 6 lug. if it is a 3/4 ton it is a corporate 10 bolt 8 lug. if it is a 1 ton it is a dana 60 8 lug... take a look in the glove box there will be a sticker in there with the alxe ratio and type of rears that are under the truck....GM stopped useing dana 44s in 1980..
Old Aug 21, 2007 | 02:39 AM
Queeg's Avatar
your probably right... i hate the thing. but we can load 8 people in it and drive to a cave or mine to explore. ill look tomarrow
many thanks scarecrow, bow2no1!
Old Aug 21, 2007 | 07:18 AM
4348rd's Avatar
if the cover has a plug to put gear oil in then it's a dana if not it's a gm coporate
Old Aug 24, 2007 | 04:10 AM
Queeg's Avatar
so its a gm 10 bolt. got that figured out after removing 3/4" of structural grease. now i need to find out where to either get parts to fix it , or a place to get it fixed in socal. what would the gear ratios be?
Old Aug 24, 2007 | 07:59 AM
Whit's Avatar
Site Mascot
gear ratio........the should be a tag attached to one of the cover mounting bolts..................if no check for a tag on the rear diff as it will have the same ratio
Spider gears dont matter what ratio ya have............unless ofcourse ya trashed the ring and pinnion
