IDM
Old Jan 31, 2010 | 10:51 AM
TwinStackPete379's Avatar
Default IDM
I got a friend that needs some help. Its an 01 7.3 stock. Truck wont start and it has a code. I dont have number but he said that the scanner said Faulty IDM. is this common on these 7.3's?. I guess i didnt realize that they were 880 dollars from Ford. and 1450 dollars from International. He said when you crank the truck it will hit and miss but no fire. only code was for the IDM,
anybody?
Last edited by TwinStackPete379; Jan 31, 2010 at 10:51 AM. Reason: Automerged Doublepost
Old Feb 1, 2010 | 04:50 PM
Nobody ever had an issue i take it?
Old Feb 3, 2010 | 10:55 PM
Colotow's Avatar
I think the code will be 1376 (could be wrong)
anyhow, friend of mine had same problem, I researched it, by the code # on here (use search box.
Anyhow, search said 99.9% of the time it's a loose or corroded connection where the wiring harness goes thru the valve cover gasket (also search "UVC" for under valve cover harness) and that's what his was. farm fixed it, zip ties and permatex, worked fine ever since
BE CAREFUL- the harness with the RED spiral tape on it goes to the injectors and it's 115v DC. it will mess you up if you probe it or grab it while it's live!!
Old Feb 4, 2010 | 05:41 AM
Awesome thanks!. I tried to search IDM but bothing came up. But i didnt have the code number. anyways .thank yo for your responce
Thanks,
kyle
Old Feb 4, 2010 | 12:56 PM
DppPower's Avatar
Was the truck acting any the last time it was running?? Was the check engine light on??
Old Feb 4, 2010 | 04:20 PM
Yes. truck ran rough. then threw a code. if i remember right it was P1297 if thats the faulty IDM code. ( i cant remember ) , when he shut it off it never re-started. It will crank and hit and miss, but never starts
Old Feb 5, 2010 | 02:06 AM
Kyle_KleinSS's Avatar
Maybe the under valve cover harness that Colotow was talking about is possible loose? Thats alot more common than an idm ive never heard of an idm failing.
akSam
15
Apr 5, 2015 01:23 PM
