fueling big hp
ive noticed the ppe duel fueler pump kits and all that for when you make big power. is something like that neccessary or is it just make it easier for the motor to keep constant fuel pressure what besides the ppe 3100 dollar dual pump kit could i do if i wanted to make alot of power
so if i had a 12v and i wanted to run 750 hp on the street and to pull and drag race with what kind of pumps and what not would i need to feed the fuel? 14mm p pump? what do i use to get the fuel to the p pump im new to modified diesels and im trying to learnim used to working on old macks and mechanical cats and big truck stuff
i agree with shea. a 13mm will fuel enough for 750. the turbos, for a dd that u pull a regular trailer every once in awhile, twins would be the most streetable. u will deffinately needs studs, and o-rings.
well i was mostly just askin about the engine specifics but yeah of course theres always driveline modifications to be done id figure a dd clutch from southbend and an input shaft and all that
