borg warner service manual
Old Jan 27, 2010 | 07:59 PM
young gun's Avatar
Default borg warner service manual
alright im stuck. im 16 in high school and attend my local vocatioanl school for diesel mechanics, and im participating in a skills demonstration for skills usa(skills competiton) and for this demonstrtion im going to take apart a borg warner turbo and put it back together and maybe make some adjustments and what not. but i need a service manual and cant find one. so if anyone has a connection to one or knows where to get one let me know please!!!!
thank
Old Jan 28, 2010 | 02:36 PM
Deezel Stink3r's Avatar
so you have choosen a difficult theme. But it shouldn't be a problem
I have some numbers to call. Describe your problem and what you want to do.
Maybe you have to visit them, but -hey- better then being helpless.
If its not what you want- I have a general nine pages manual on how to overhaul a turbo, just let me know if you want to have a copy.
Old Jan 29, 2010 | 10:53 AM
young gun's Avatar
well i have to demonstrate a skilll. so basically i need the manual to find like parameters for like endplay ion the shaft and what not. and i just need numbers
Old Jan 29, 2010 | 11:25 AM
Same procedure:
call them, explain your problem-they will help you.
be smart and have the turbo and all its part number ready at hand:
BorgWarner Turbo Systems
PO Box 15075
Asheville, NC 28813
USA
Tel. 001 828 684 4000
Fax 001 828 684 4030
E-Mail info-na@borgwarner.com
If you want to rebuild a charger you have to call the turbo distributor anyways to get the specs to make sure the dimensional measurements for wear are correct and will allow reuse of critical components.
Once you have the specs you can compare them to your turbocharger to ensure you have a live player.
You need:
- turbine shaft diameter
- bearing housing bore inside diameter
- Turbine stub shaft run out
- compressor wheel nut torque spec for reassy
- tilt at compressor nut
But you won't get anything without providing type and turbocharger series.
How much time do you have left?
Last edited by Deezel Stink3r; Jan 29, 2010 at 11:27 AM. Reason: Automerged Doublepost
woodsman27
May 23, 2015 10:16 AM
robertleo
Mar 9, 2015 08:46 PM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
