p7100 fuel pump ?
Old Jan 27, 2010 | 12:56 PM
fliptikal's Avatar
Default p7100 fuel pump ?
i have a 1996 cummins...i've heard a lot of talk about turning the star wheel to dump more fuel into the injectors...my question is...where is this star fuel located? can someone please point it out for me?
Old Jan 27, 2010 | 01:24 PM
93_Fummins's Avatar
It's under the Allen head plug on top of the AFC. Check out the AFC Tuning article floating around here; it's an awesome pdf put together by a member that gives step by step instructions to tuning the AFC, with pictures and everything!!!
AFC Tuning
Last edited by 93_Fummins; Jan 27, 2010 at 01:24 PM. Reason: Automerged Doublepost
Old Jan 27, 2010 | 01:31 PM
Jazz's Avatar
Here is another thread you may want to read through https://www.dieselbombers.com/5-9l-1...-12-valve.html
Old Jan 27, 2010 | 08:24 PM
R&RDiesel's Avatar
FormerVendor
Dosnt really give you more fuel, just more fuel at lower rpm's so it smokes a little more, but does not add more additional fuel.
Old Feb 3, 2010 | 10:35 PM
IH1206's Avatar
fuel plate will do the same thing and its a little easier.....
Old Feb 3, 2010 | 10:38 PM
12valvetater's Avatar
It does not do the same thing.
Old Feb 3, 2010 | 10:41 PM
Benjamin's Avatar
Bombardier
loosening the star wheel adds fuel at a quicker rate as boost increases, dosen't add more in a total aspect but it adds more than stock in the lower RPM when boost is applied.
BTW it is under the screw with the allen hole in it. it is an 8mm allen wrench to remove it. get a quality allen wrench because it might be really tight. no need of breaking a cheap one....
Old Feb 3, 2010 | 10:42 PM
IH1206's Avatar
idk if he wants a quick fix for power, fuel plate is just an answer, in my eyes it seems like they both give it a little more pep, but w.e.
Old Feb 5, 2010 | 11:50 PM
R&RDiesel's Avatar
FormerVendor
A fuel plate will give you more fuel, turning the star wheel just changes the amount of fuel is delivered with the amount of boost, but will not add more fuel out of the pump.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
