Coolant Leak
Old Jan 26, 2010 | 04:32 PM
Herman's Avatar
Default Coolant Leak
My 2000 Ford F250 Superduty 7.3 leaks coolant at front of engine only when cold.Sometimes nothing sometimes a steady drip.I cant see weephole and havent had a water pump go out and leak only when sitting still and cold.Cold in San Diego is 60 degrees.Thanks in advance.Jim
Old Jan 26, 2010 | 04:42 PM
Whit's Avatar
Site Mascot
coolant leaks can be hard to find up front like that because the fan blows the coolant all over the place and ya cant pin point it..........I would bet on the water pump myself, if it has over 100k on it then replace the pump, they are cheap anyway so this would be no biggie
Old Jan 26, 2010 | 08:39 PM
CSIPSD's Avatar
Its the water pump... It may last a lot longer it may not!
Old Jan 27, 2010 | 10:37 AM
codiesel's Avatar
ya its the water pump ythey are noted for it to go and it does excale what you described
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
