6.9L & 7.3L Performance Discussion of 83-94 6.9 and 7.3 Liter Ford Diesels Related to Performance and Longevity
6.9 usable parts to transfer from 7.3
Old Jan 18, 2010 | 07:36 PM
86F2506.9,77F2506.6's Avatar
Default 6.9 usable parts to transfer from 7.3
Lookin for a good way to get some good power out of my 6.9 the fuel pump is turned up and i have a turbo kit on the way but i was wonderin if there was a fuel pump or maybe injectors for the 6.9 but i was told most stuff from the 7.3 idi works for the 6.9 but does anyone know if stuff from the newer 7.3 powerstrokes would work.
Old Jan 19, 2010 | 06:31 AM
DieselCrawler's Avatar
nothing from strokers will work cept the oil filter.
Old Jan 19, 2010 | 09:11 PM
well does anything aftermarket for the 7.3 idi work for the 6.9 other than the trubo kits of course
Old Jan 20, 2010 | 05:36 AM
yes, everything will work except the headstuds and pistons. everything esle will bolt on.
a 7.3 idi is a bored out 6.9. has same stroke, just bigger pistons.
Old Jan 28, 2010 | 12:33 PM
cowboyford16's Avatar
will you get more power by taking the 7.3 injectors and putting them in a 6.9. Or are they the same size?
Old Jan 28, 2010 | 04:29 PM
the injectors go by codes.
a stock 83 6.9 will have letter code "a" injectors. 84+ they go up. from "a" to "aa" all the way up to f.
letter code "g" injectors are for a 94 Idi with the factory ATS turbo.
changing to the bigger injectors will help a little, but not much without more air.
Old Jan 29, 2010 | 01:28 PM
so the letter f or g is the biggest injector you can fit on a 6.9? What did you do to your 6.9 to get more fuel or what is the best advise you can give me to get more fuel on a budget.
Old Jan 29, 2010 | 05:19 PM
sootman's Avatar
the best stock idi injector is a "bb" code injector. they came in the 93 turbo idi's. g codes came in the 94 idi's but they were a emission injectors and don't make all that much power
or you could contact mel on oilburners.net and get his moose injectors and moose pump. only performance fuel mods currently for our trucks.
Old Jan 31, 2010 | 01:56 PM
i went to oilburners and i cant find this person use said to contact because id like to know how much they want for the injectors and pump
Old Jan 31, 2010 | 06:41 PM
his handle there is agmen, i belive.
