Will new nozzles effect pop pressures?
Old Jan 18, 2010 | 04:26 PM
chpmnsws6's Avatar
Default Will new nozzles effect pop pressures?
Out of curiosity, when installing new nozzles, would the pop pressure change? In theory, they should remain the same. I'm just not sure if that is the case in the real world.
Any insight?
Old Jan 18, 2010 | 07:47 PM
Anytime you replace nozzles you have to have them pop tested.
Old Jan 18, 2010 | 10:29 PM
chpmnsws6's Avatar
The reason I ask is the injectors in question were adjusted maybe 1,000 miles ago, but with the same ole tiny RV275 nozzles.
Old Jan 18, 2010 | 11:09 PM
If you install new nozzles you have to have them re-tested.
Old Jan 19, 2010 | 04:42 PM
thebullet83's Avatar
if there is any variance in length of the nozzles, the spring pressure changes. that's why there are shims in the body- to get the pressure right.
but i did nozzles and didn't pop test them, and seems to work great, at least seat of pants test
Old Jan 19, 2010 | 04:43 PM
Sometimes you can get lucky and they run fine. 9 times out of 10 they wont.
Old Jan 20, 2010 | 12:36 AM
chpmnsws6's Avatar
Time to buy the equipment to pop test them....... I'm sick of paying other people to do something I know how to *sigh*
Old Jan 20, 2010 | 09:10 AM
Codgedodger's Avatar
FormerVendor
Good luck finding an adapter for the injectors. I had a hell of a time finding one and there not cheap.
Nov 30, 2014 02:10 PM
hardeercy
Nov 23, 2014 04:20 PM
