6 speed to an Allison.
Old Jan 15, 2010 | 09:39 PM
KuNtRy BoY's Avatar
Default 6 speed to an Allison.
I currently have a 6 speed in my 03 dmax, its doing fine just want somehing different. I am wanting to covert to an auto(stage 4). I do have a donor truck already. Does anyone have any idea what I all I will need for the change over?
Old Jan 15, 2010 | 10:22 PM
tdiezel's Avatar
I was unaware that Chevy even offered a 6 speed tranny! But regarding the swap. Allison is made to go in the Chevy and the Chevy body is made for the Allison. Im pretty sure you could fit one no problem. Also pretty sure you wont need an adaptor plate or anything. The electrical side will need some changes to accept the automatic tranny and you may need a different length rear drive shaft. The T-case is the same on both I believe so you are pretty much set I think with just the tranny and wiring. The only I would be concerned about is the rear drive shaft and even then you may be in the clear. Someone else will more than likely be able to answer that question.
Old Jan 16, 2010 | 11:30 AM
KuNtRy BoY's Avatar
They are rare but they did have 6 speeds in the dmax. The donor is the exact same as mine except a 02, everything else the same, but i will use my transfer since the other is bad. Just wondering what all ill need off of the wiring harness, and if it wiould match up with no prob.
Old Jan 16, 2010 | 09:09 PM
92typhoon937's Avatar
so u have one of the rare 6 spd chevys i wanted and couldnt find n u gonna put an auto in it
Old Jan 16, 2010 | 09:33 PM
KuNtRy BoY's Avatar
Ya im really looking at it, I was gona go with the southbend clutch, but the auto will keep my spool up.
Old Jan 16, 2010 | 09:37 PM
K50's Avatar
K50
yeah if you lived closer I'd say do a straight swap with my '03.
Old Jan 16, 2010 | 09:39 PM
KuNtRy BoY's Avatar
Ya that would be nice
Old Jan 16, 2010 | 11:57 PM
dieseldocter16's Avatar
Why do you want an auto behind the d-max? My buddies 07 2500 classic fried the 6 speed allison w/ just an tuner and exhaust.
Old Jan 17, 2010 | 07:13 AM
KuNtRy BoY's Avatar
Im gona go with a suncoast lV
Old Jan 17, 2010 | 07:26 AM
2500HeavyDuty's Avatar
you can do that to any stock auto with just a tuner on a dmax, they make some stoopid power.
