6.2 HARD START ROUGH RUNNING HELP
Old Jan 15, 2010 | 08:34 AM
smoking62's Avatar
Unhappy 6.2 HARD START ROUGH RUNNING HELP
hey guys im 18 and have alot of experiance with smalll engines. diesels are another story. i have a 6.2 and it leaked fuel through the valley... so i bought a 35 dollar pump off ebay it was an as is buy. well i slapped it together and it wouldnt fire. so i took the top cover off the pump and filled it with diesel, and it ran hard when i throttled up it rapped out quickly at half throttle but it idled. when i got the pump i turned the fuel screw up and i noticed that the arm that pivots when the throttle lever is rotated, it pushes a little rod in the pump. well the ajustment screw was all the way out. on my old pump it was in all the way? i took it on a half mile test drive and it died and woudnt start please help
Old Jan 15, 2010 | 10:15 AM
Deezel Stink3r's Avatar
Did you open the injection pump?
Ok, pumps are very sensitive to air inside the pump and adjustment.
Have you found out where the old pump was leaking?
Repair sealing sets are cheap.
It seems that you now have more than one problem.
Old Jan 16, 2010 | 05:18 PM
wildbill's Avatar
Turn the key on, but don't start the engine. Remove the thick red wire from the injection pump. If there is a loud click, good. A weak or no click, need a new shut off solenoid. With the same wire, check the check valve. If it clicks with the red wire, but not the green one, run a jumper to it.
ssmith.77
Nov 25, 2018 06:56 AM
94turbostroker
Feb 26, 2016 07:51 PM
bdbfam
Aug 31, 2015 09:06 PM
Blanton
Apr 15, 2015 06:29 PM
ssmith.77
Jan 11, 2015 02:03 PM
