12 valve in a swb dodge 1/2 ton
Old Jan 13, 2010 | 04:03 PM
1fastsilverado's Avatar
Default 12 valve in a swb dodge 1/2 ton
how hard of a swap would this be? also anyone ever done this? how much money would i be looking at? would $5000 cover it? also would the gauge cluster work with the swap? my buddy is looking into doing his in a few weeks, and he has me hooked. all info is greatly appreciated.
Old Jan 13, 2010 | 07:17 PM
streetrod's Avatar
i have looked at putting a diesel into a 1/2 ton dodge truck and i believe that the axels would need to be changed to handle the weight with that being said i do not believe that the control arm mounts are not in the same place so this was the reason i stopped the swap i was looking at doing
Old Jan 13, 2010 | 11:18 PM
dealwithit's Avatar
2007 Dodge Ram - Cummins Diesel Engine - Diesel Power Magazine
Old Jan 18, 2010 | 08:43 PM
440warwagon's Avatar
What year Dodge and 2wd or 4wd?
Old Feb 15, 2010 | 06:54 PM
SmokeN 12 ValvE's Avatar
I am in the process of doing this with a 96 reg cab short bed 4x4, the front axle was a direct swap to a dana 60, the rear axle perches have to be cut off and moved out some.
Old Feb 22, 2010 | 09:24 PM
smokincummins92's Avatar
You could just put a 4bt in it. I dont thank you would have to swap axles then. Pluse its not as big ofcourse so you would have less to modify. Im putin a 4bt in my 85 1/2 ton dodge 4x4. Weighs about as much as a big block v8.
Stone007
Tech Article Submission
Jul 3, 2015 01:28 PM
PeteBug
Jun 11, 2015 12:16 PM
river rat
May 18, 2015 05:04 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
jac60
Oct 28, 2014 03:29 PM
