Need help w/ my 6.0
Old Jan 14, 2010 | 07:36 AM
MUDSTROKIN''s Avatar
Default Need help w/ my 6.0
p0261- injector circut low cylinder 1
If you know how to fix this or what part it is or can even narrow it down to my problem i would greatly appreciate it.
I have lost some power and i am getting shitty MPG!!!
Someone please help me!!!!
BUMP
Last edited by MUDSTROKIN'; Jan 14, 2010 at 07:36 AM. Reason: Automerged Doublepost
Old Jan 14, 2010 | 07:40 AM
12vcummins96's Avatar
injector has gone south
Old Jan 14, 2010 | 09:27 AM
What do i need to do to fix it? replace the injector? or is it just dirty or what? In the past 2 fill ups i've put in some powerservice diesel supplement and some 2 cycle oil...
And if thats the case do i just repace that one injector?
Old Jan 14, 2010 | 09:52 AM
Diesel Nut's Avatar
First, I would get ahold of someone with a scanner. Clear the code, then buzz the injectors. This will release any additional FICM codes. If the code for #1 returns, then I would pop the valve cover and see if there is any noticeable wiring damage. These trucks love to chaff wires. If you can't find any damage, then it could be an injector, but then again it could be a FICM as well . . . .
EDIT -
DISCONNECT THE EDGE! See if the problem persists after that. We are pulling them off trucks left and right for failures. Do this first.
Old Jan 14, 2010 | 10:01 AM
i buzzed the injectors before i pulled this code. Buzz test passed...
Old Jan 14, 2010 | 10:05 AM
Diesel Nut's Avatar
So, this code appeared after you buzz tested the injectors? Clear the code and buzz them again. If you have a low volt on cir 1 you will get that code at the conclusion of the buzz test. Thats the whole point of the buzz test.
Old Jan 14, 2010 | 01:45 PM
You got jokes
Nut i'm lost as to what your sayin?? I'm supposed to get that code after running a buzz test? bc the codes were cleared before i did the buzz test??? If my injector is bad i'm guessing that explains my loss in power and shitty MPG?
Last edited by MUDSTROKIN'; Jan 14, 2010 at 01:45 PM. Reason: Automerged Doublepost
Old Jan 16, 2010 | 01:50 AM
Diesel Nut's Avatar
When you buzz the injectors that also allows the FICM to release internally stored codes that may not show up normally. If the code was not present before buzzing the injectors then its a stored code. If you clear the code, then buzz the injectors, if the code returns you have an issue that requires addition investigation. If the code does not, don't worry about it too much.
Old Jan 16, 2010 | 05:24 PM
wildbill's Avatar
Updates??
Old Jan 19, 2010 | 08:06 AM
No the code wasn't there before buzzing the injectors. i buzzed the injectors and it popped up? Any idea as to how to find out what the actual problem is? From what i've heard and read it could be anything from chafed wires to the ficm to a bad battery??
