Truck wont start how do i check the cp3
Old Jan 12, 2010 | 04:43 PM
bway1341's Avatar
Default Truck wont start how do i check the cp3
Truck wont start how do i check the cp3 i put on a fass and truck started shut it off and will not start back. I have loosen the filter and made sure all air was out. and the pump is pumping, i have also check all fuse's. Anyclues?????????????? Truck has been down a month
Old Jan 12, 2010 | 07:22 PM
wildbill's Avatar
Have you got fuel to the CP3??
Old Jan 12, 2010 | 09:23 PM
Diesel Nut's Avatar
Double check to make sure you have the routing on the FASS correct. You wouldn't believe how many folks get the return and engine supply backwards and with the fass returning everything to tank the motor gets nothing. Start there.
Next, do you have any white smoke while cranking? If so, you have an injector stuck open.
Old Jan 16, 2010 | 05:00 PM
wildbill's Avatar
Updates??
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
