NV4500 - NV5600 Questions!!
Old Jan 12, 2010 | 01:22 PM
upINsmokeDiesel's Avatar
Exclamation NV4500 - NV5600 Questions!!
So I pretty much totally blew the nv4500 5spd in my truck ....
I really like driving the nv5600 6spd trucks better...
So here is what I found... A NV5600 6spd. with a bad 2nd gear syncro for $1130.00 shipped to my door. The truck it came out of has less than 90,000 miles on it.
Here are my questions..
Is it a good deal?
How much for a 2nd gear syncro?
Can I use my transfer transfer case with the 6spd?
And what all do I need extra to make it work?
I have a brand new south bend clutch & input shaft for my 5spd.. Is there any market to sell them used with very few miles on them..
I can buy a rebuilt nv4500 off ebay with a 1 year warranty & the upgraded 5th gear fix for $1275 Shipped..
What would you guys do? Need to make up my mind fast
Old Jan 12, 2010 | 01:29 PM
Jet A Fuel's Avatar
NV4500 would be easier you have all the stuff for it already. If you go six speed you will need the 13 inch clutch/flywheel around 900 dollars for a medium range HP clutch. If you wanna sell the old NV4500 I would be interested.
Old Jan 12, 2010 | 01:32 PM
Lil Red Express's Avatar
Just put the 5th 5spd and 6th clutch in my moms 97 So if you have the coin since its already apart I would swap in the 6spd. Much tougher trans IMHO.
Old Jan 12, 2010 | 01:48 PM
How much would the blown nv4500 & clutch & input shaft & flywheel be worth?
Old Jan 12, 2010 | 02:59 PM
Jet A Fuel's Avatar
got any pictures, what blew out
You my need the old NV4500 for a core (if you stay with the 4500) most times the price people give is for an exchange transmission.
Last edited by Jet A Fuel; Jan 12, 2010 at 02:59 PM. Reason: Automerged Doublepost
Old Jan 12, 2010 | 04:36 PM
I will post some a lil later
Old Jan 12, 2010 | 08:08 PM
chpmnsws6's Avatar
What kind of power are you putting down? Intended use for the truck?
Old Jan 12, 2010 | 09:04 PM
CumminsCrazed's Avatar
good luck finding a synchro for the 6 spd!!!!!
Old Jan 12, 2010 | 09:20 PM
Diesel Nut's Avatar
They aren't so hard to come by. . . . . . .
When you say you have the new input from South Bend, I am assuming its the 1 3/8" input. If so that means you HAVE to have the 13" clutch therefore the 6 speed will take the same clutch. Just change the transmissions and I think the crossmember.
Old Jan 12, 2010 | 09:44 PM
chpmnsws6's Avatar
I also heard through the grapevine the driveshafts also need replaced/modified
