something wrong in the front axle.
Old Jan 11, 2010 | 08:57 PM
vcustoms86's Avatar
Default something wrong in the front axle.
I have 2 problems. The truck is only getting 14-15 mpg. Usually gets 19-21. Opened a thread before on that. Second, my 4wd light keeps flickering off and on till i get rolling. What i have noticed is that when i turn the truck to the left, 4wd light comes on and stays on till i have been moving forward for a bit. When i turn to the right, either the light goes out or if its not on, it doesnt come on. its not feeling like a wheel bearing/hub assemblie issue. had them both go out on me before and they didnt do this. Also, when i first start out i can barely hear and feel a little grinding coming from the front end. Does anyone have any idea what is causing all of this? im going to double check the hubs in the morning. Then im going to spin each wheel to see if the front driveshaft moves. If one side moves it, whats wrong with the axle? Please guys i reall need help. Im afraid if i keep driving it i might burn up the whole axle.
Old Jan 11, 2010 | 09:06 PM
ArizonaRedneck's Avatar
does it have manual or auto hubs minedid the same thing with manual hubs no 4-wheel light i could just hear it and feel it on the left side my selector had broke on the inside when taking it out of 4 wheel drive a couple of days earlier and the left side was still engaged
Old Jan 12, 2010 | 05:09 AM
vcustoms86's Avatar
it has auto hubs. i have been wanting to swap in manual hubs but need $$$$ for that
Old Jan 12, 2010 | 09:50 AM
Diesel Nut's Avatar
Technically you have no hubs. Its a drive flange at the wheel and a center axle disconnect on the passenger side axle tube.
Does the truck operate normally in 4x4? I am thinking you have some wire chaffing going on, 4x4 indicator is sensed off the transfer case if memory serves.
Old Jan 12, 2010 | 09:56 AM
94cummins12v's Avatar
most likely that vacuum switch on the tcase the light only comes on the front cad is enguaged completely. mine did it to the switch is 12 at napa i just put one of those vacuum switches on mine for a exhaust brake so i can run my cad by a toggle switch
Old Jan 12, 2010 | 06:46 PM
vcustoms86's Avatar
i know technically there isnt any hubs. the truck operates fine in 4x4. no issues. What about the vacum actuator on the axle itself? i was looking under the truck and i noticed i could move that actuator back and for quite easily. is that normal or is that a sign of something?
Old Jan 12, 2010 | 07:10 PM
rjjp's Avatar
With the truck running it should take an act of god to move that with out changing it inside the cab.
Old Jan 13, 2010 | 10:41 AM
vcustoms86's Avatar
i'll fire it up and try again.
ok even with the truck running i can still wiggle that actuator up and down. my 4x4 works fine so is it the actuator thats bad?
Last edited by vcustoms86; Jan 13, 2010 at 10:41 AM. Reason: Automerged Doublepost
Old Jan 16, 2010 | 05:08 PM
wildbill's Avatar
Anyway of adjusting the slack out of it??
Old Jan 18, 2010 | 04:30 PM
vcustoms86's Avatar
put a new actuatuor in. works fine now. fuel mileage is back up to normal. tightened everything down a little too much i think and i broke the 4wd indicator switch. oh well. just another thing to fix.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
