05 dodge 48re 1-2 shift problems
Old Jan 11, 2010 | 06:15 PM
1guntoofew's Avatar
Default 05 dodge 48re 1-2 shift problems
have a 05 2500 4x4 that i put a new front band in from the bottom about 2 weeks ago and new gov sensor and regulator and everything was working fine until yesterday it started winding till it gets to about 20 mph then shifts hard to second. its throwing p1754 code which is tva motor. any suggestions before i change the motor. seems odd to work for 2 weeks then mess up if something was not put back right. i pulled tvm off and shaft doesn't seem to be bound. thanks ta
Old Jan 11, 2010 | 08:43 PM
DieselDanBoy's Avatar
have you replaced the tva motor before?
Old Jan 11, 2010 | 08:50 PM
1guntoofew's Avatar
125k never replaced anything till 2 weeks ago in this tranny
Old Jan 12, 2010 | 07:26 AM
good chance that motor needs to be replaced then.
Old Jan 12, 2010 | 09:47 AM
Diesel Nut's Avatar
If you have a code for the TV motor then I would start there. If you happen to know someone else with an 05-07 5.9 auto, borrow theirs for a quick trip around the block. Our diagnostic equipment allows us to read actual sweep of the TV motor, but if you don't have access to that then a quick swap is the easiest way to test it. Hows the 2-3 shift? Sloppy? If so, try adjusting your front band again.
Old Jan 16, 2010 | 04:54 PM
wildbill's Avatar
Updates??
Old Jan 19, 2010 | 06:32 PM
1guntoofew's Avatar
tva motor fixed it. 140 bucks from local dodge dealer.
jrock0805
Jul 28, 2015 02:03 PM
Ohiocummins99
Jul 8, 2015 07:30 AM
rabidrabbit
Mar 6, 2015 03:47 AM
Tucker126
Jan 2, 2015 08:09 AM
Nov 3, 2014 08:10 AM
