Street And Track Racing Diesel Discussions of Street And Track Racing Practices , Techniques , Tips and Kill Stories PLEASE BE CIVIL
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Boost Launches
Old Jan 10, 2010 | 08:38 PM
02WhiteandBlack's Avatar
Default Boost Launches
Ok iv got two questions...
First when i boost launch I usually just run it up to 1400 rpm in first and dump the clutch, well the other day i was racein my buddy in a mostly stock common rail and knowin his truck if i could get him off the line i could beat him so i ran it up a lil higher maybe 1600-1700 rpm and when i dumped the clutch again in first it hoped twice and then the diff poped into nutreal is there sometin wrong or just to high of rpm because this is the second time its done it...
And this leads to my next question how are some guys boost launchin in third gear and 2000 rpm? aftermarket clutch? or is there a special way you have to do that?
Old Jan 10, 2010 | 08:40 PM
94cummins12v's Avatar
when i do boosted launches i do them in 3rd 1st you dont realy gain anythinf secound is better. i do 3rd gear boosted luanches with 10psi of boost by reving it up then dumping the clutch your onching it like an auto
Old Jan 10, 2010 | 08:57 PM
Do you let the clutch out slower or do u dump it because anytime iv tryed to dump the clutch in anything high than 1st it wants to stall out and seems alot slower than dumpin in first
Old Jan 10, 2010 | 09:09 PM
kazairl's Avatar
I usually rev it to about 2400 or so and let the clutch out quickly. Don't dump it but try letting it slip a little before you let it all the way out.
This is in no way conducive to long clutch life. I would not recommend it on a stock clutch.
Old Jan 10, 2010 | 09:12 PM
Ya im more worried about clutch life so i think ill stick to what iv been doin
Old Jan 10, 2010 | 09:40 PM
Lil Red Express's Avatar
I use run my old 97 up to around 2800 and let the clutch out in 3rd. Went through several clutchs even bigger aftermarket ones. Along with several 5spds.
Old Feb 13, 2010 | 02:11 PM
07redsled's Avatar
pull out in 2nd and learn how to shift faster
Old Feb 18, 2010 | 12:28 AM
bajabomber87's Avatar
How big are your tires and what gears do you have if 2nd isn't working?
Old Feb 18, 2010 | 01:29 AM
even with my 37" tires i have no issue doing boosted 3rd gear launches when i hit the strip i even do it id 4hi then release the hubs when im in 5th
Old Feb 18, 2010 | 06:11 AM
mfolsomblueD's Avatar
Bring them up to about 2800-3000 and just dump the clutch in 2nd and then hit 3rd quickly and if your shifts are good that will get you off the line
