Perkins 4.236 in 75 Range Rover
Old Jan 10, 2010 | 02:20 PM
JimmymacD's Avatar
Default Perkins 4.236 in 75 Range Rover
Hi, UK newbie after some advice.
Just bought 1975 Range Rover with a Perkins 4.236 conversion. Came minus ignition, cooling and power steering. All sorted except engine preheat which sits in intake manifold with a fuel pipe. There are no electrics to it. I have tested it and it heats up OK. Does anyone have a wiring diagram or know what relays and wiring I need to create a push button or ignition preheat feed to the manifold?
Cheers, JimmyMac D
Old Jan 10, 2010 | 09:49 PM
dealwithit's Avatar
well you should be able to just use a push button to a relay then from the relay to the power source, ground, and to the heater.
Old Jan 11, 2010 | 02:32 AM
JimmymacD's Avatar
Thanks for the info, when you say power source, is that straight from battery or is there enough juice through LT wiring on ignition? I take it that the relay is earthed?
Cheers Jimmymac D
Sep 8, 2015 02:40 PM
Jun 4, 2015 09:30 PM
Apr 15, 2015 04:30 PM
Mar 19, 2015 07:10 PM
Feb 23, 2015 06:20 PM
