Timing Opinion
Old Jan 5, 2010 | 08:52 PM
dansdieselp's Avatar
Default Timing Opinion
Hey guys we got a 12v Cummins built and would like to hear what you guys think on what we should set the timing to. Here is what is done.
Fire ringed head and 12mm ARP studs
Biggest delivery valves for stock pump
4000 rpm gov. spring kit
Maxed out fuel plate
Mack rack plug
Big Stick cam from Colt cams
.093 injection lines.
100% over injectors set to 3900 psi cracking pressure.
ATS exhaust manifold
BW S400 2.6 turbo
CFM intake elbow
AirDogII-165 lift pump
It has a ZF6 with 900hp dual disk clutch from SouthBend.
The truck will sled pull a couple times a week and also be a daily driver. What do you guys think? I set it to 18 degrees, but I'm starting to lean towards 20. Would like to get the most power we can. Also needs to be able to start easily, especially when it's cold out. Thanks.
Old Jan 5, 2010 | 11:16 PM
12.valve.hauler's Avatar
i would go with somewhere between 18.5 and 19.5
Old Jan 6, 2010 | 08:40 AM
STUMPMAN's Avatar
Go right in the middle at 19. With those mods you could set it at 30 and buy a case of either to start it everyday
Old Jan 6, 2010 | 09:14 AM
PhilipR's Avatar
Have fun with those fire rings on the street.....I agree with Stumpan....19*
Old Jan 6, 2010 | 10:19 AM
Thanks guys. I'll probably set it to 19 and see how it performs.
Old Jan 6, 2010 | 10:40 AM
PhilipR's Avatar
Keep an eye on the CFM plus intake, Those have been known to blow at higher boost numbers.
Old Jan 6, 2010 | 11:24 AM
94 12valve's Avatar
what is the spray angle of the injectors 145* or 155*? what injector washers did you use?
Old Jan 6, 2010 | 11:27 AM
12valvetater's Avatar
What size injectors are they, hole size?
Old Jan 6, 2010 | 11:29 AM
94 12valve's Avatar
stock pistons?
Old Jan 6, 2010 | 11:56 AM
12vcummins96's Avatar
mine is set at 21*
