6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Ford 6L egr valve disconnect
Old Jan 4, 2010 | 02:02 PM
DUMDOWN's Avatar
Default Ford 6L egr valve disconnect
I disconnected the egr valve by pulling the electrical plug.
Didn't get any chech engine light but the shift point for the transmision shift
went up by at least 500 RPM. This is in the tow/haul possision.
Shifts normal out of tow/haul.
ANY SUGESTIONS?
Old Jan 6, 2010 | 04:52 PM
powerstroke7's Avatar
I would plug it back in and see if it gets any better an if it does get better I would leave it plugged in
Old Jan 13, 2010 | 05:25 PM
conner's Avatar
Are you running a tuner? Because you can get a tune that will shut off the egr valve and not have a problem with it again. But I used to do what you are doing and never noticed a higher shift point
Old Jan 22, 2010 | 05:10 PM
grabber1's Avatar
What does the EGR do for the truck when it is not in use? Sorry..NEWBIE
Old Jan 22, 2010 | 05:41 PM
HeavyAssault's Avatar
ANY SUGESTIONS?
The TH button will cause your shift points to be higher normally. Are you saying that it's shifting at 500 higher than before when using TH?
Old Jan 22, 2010 | 07:49 PM
grabber1's Avatar
It's supposed to shift at a higher point when in TH. It makes it so that it holds the gear longer when towing.
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
makuloco2000
Dec 7, 2014 11:15 AM
behrendt1061
Dec 4, 2014 05:49 PM
