2004 f350 diesel problems
Old Jan 2, 2010 | 11:28 AM
mfannm@aol.com's Avatar
Question 2004 f350 diesel problems
It figures 8 weeks out of warranty, and problems start. Noticed small oil drops in garage.Then when idling the check gauge light comes on, oil pressure gauge drops, when you accelorate the light goes out and the oil pressure gauge goes back to normal.
I am a woman and not mechanically inclined, but I really need help. Could this be the oil pressure sending unit...and if so where is located and what is the difficulty in replacing it--
Thanks alot
Woman in distress
Old Jan 2, 2010 | 06:32 PM
wildbill's Avatar
Could be the sending unit, or the oil pump, or oil that's too thin. Find out what code or codes are setting.
Old Jan 2, 2010 | 06:35 PM
jbrown1132's Avatar
keep the dip stick more often if you have a leak. you don't need to run the engine too low on oil
Old Jan 3, 2010 | 12:43 AM
BC06PSD's Avatar
You could have a cracked front cover. PM sent.
Old Jan 3, 2010 | 08:15 PM
Default cracked front cover
How to I check for this, or should I say where do I check for this. Remember, I am not very mechanically inclined, so I can use all the information you can give me. I replaced the sending unit today. Gauge is right where it should be. Changed the oil 2 weeks ago.
Old Jan 5, 2010 | 01:09 PM
wildbill's Avatar
Updates??
Old Jan 13, 2010 | 09:56 AM
wildbill's Avatar
Please update.
Old Jan 13, 2010 | 06:30 PM
I haven't got any updates yet. Have found a mechanic in my area that will not rip a woman off, his on vacation this week, should know more next week........
Old Jan 14, 2010 | 09:59 AM
Diesel Nut's Avatar
So you still have an issue after sensor replacement?
Old Jan 16, 2010 | 05:10 PM
wildbill's Avatar
Updates??
