Does this seem right?
Old Jan 1, 2010 | 01:41 PM
megawagon's Avatar
Default Does this seem right?
So recently as some of you may know I added 90hp injectors and a smarty to my truck...It hasn't been running right since. HIgh egts and bad fuel pressure (high/low) Engine bogs like a gasser at times.
So just for giggles I put my Superchips flashpaq back on and it seems to be running like a champ...Low egts, but fuel rail pressure at idle is 8-9k and on the gas its 14-16k at cruise its 19-21k.
I know that the flashpaq isn't made for a truck with mods, but it seems like its running great? anything I am missing?
Thanks!
other mods are aurora ats 3000 turbo, industrial injection 90hp injectors, afe CAI, afe intercooler, magnaflow turbo back exhaust, afe arcflow, ats manifold...
Old Jan 1, 2010 | 02:51 PM
dangerous1965's Avatar
The chip isn't as aggressive at fueling as the Smarty So your still within your fuel systems capabilities.
Old Jan 1, 2010 | 03:27 PM
cbrahs's Avatar
what version of smarty you running? If Revo- what settings are you running?
Old Jan 1, 2010 | 04:54 PM
cerberus60's Avatar
The Flashpaq is relying on pressure to make the power and either not modifying duration or mildly tweaking it. The Smarty relies on a lot of duration to make the power and is a lot harder on the fuel supply than a pressure box.
Idle is a little high but its not gonna hurt you. Under power the pressure is even lower than it should be but high enough to make it run better without a lot of duration.
Runnign 19-21k for extended period is pushing the limit on what the injectors will take for an extended period. Would be much better if 17-19k was cruise but they seem to handle 19 or so if you keep the fuel clean and pressure up.
