blew diesel fuel heater fuse
Old Dec 25, 2009 | 11:51 AM
farmboy's Avatar
Angry blew diesel fuel heater fuse
i own a 99 diesel cummins 24 valve. i was driving it yesterday and it just died. pulled the truck home checked fuses and found a 40 fuse for the diesel heater blown, All i had was a 30 and it instantly blew that, will throw in a 40 when stores open tomorrow. if it blows what then?? Can anyone give me any suggestions.?? it seems like every month i am going through some seriously expensive breakdowns
Old Dec 25, 2009 | 11:55 AM
wildbill's Avatar
Heater must be shorted out. Unplug it, and replace the fuse. If it blows again, there must be a short between the fuse and the connector.
The heater is located on the side of the filter canister.
Old Dec 25, 2009 | 12:08 PM
99stackedpowerstroke's Avatar
yes the heater is shorting, you can unplug it and still drive it just fine with no problem, good luck
Old Dec 25, 2009 | 12:12 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and what other problems are you having like why did you have to pull it home
Old Dec 25, 2009 | 12:14 PM
wildbill's Avatar
Here's the info on replacement.
Attached Thumbnails blew diesel fuel heater fuse-fuel-heater.jpg   blew diesel fuel heater fuse-fuel-heater-ii.jpg   blew diesel fuel heater fuse-fuel-heater-iii.jpg
Old Dec 25, 2009 | 12:23 PM
so if you lose this fuse bill it will shut down the truck
Old Dec 25, 2009 | 12:32 PM
wildbill's Avatar
I hope it doesn't do more than that, like fry my ECM.
Old Dec 27, 2009 | 09:48 AM
farmboy's Avatar
thanks for info ill try unpluging the heater
Old Dec 27, 2009 | 09:52 AM
12vcummins96's Avatar
good luck and hi
Old Dec 30, 2009 | 09:41 AM
wildbill's Avatar
Updates??
