gen 1 in 99 24 v
Old Dec 21, 2009 | 07:13 PM
BIG RON's Avatar
Default gen 1 in 99 24 v
i got a 99 1 ton dodge cheap with blown 24 v in it, want to put my gen 1 12 v in it other than doin away with all the computerized hoopla, will everything else work with the 99 harness
Old Dec 21, 2009 | 08:34 PM
RSWORDS's Avatar
probably not... The 1st gen dont really use and wiring harness to speak of... Getting teh engine running would be easy, getting all you gayges to work not so much.
Old Dec 22, 2009 | 01:54 PM
BigDiesel359's Avatar
Whats wrong with the 24V thats in it?
Old Dec 22, 2009 | 02:53 PM
BIG RON's Avatar
its got a rod stickin through the bottom of block guy i bought it from says he thinks crank is broke too,i dont know crank is broke for sure,i havent got into it yet,just thought it would be easier to put the 12 v in bein how i got it here and low miles, and its paid for
Old Dec 22, 2009 | 04:42 PM
biged681985's Avatar
i am just the person u need to talk to
first off, if its a manual, it will be alot easier.
second, no matter what, the stock tach will not work.
third, if it is an auto, then u will have to rig up an overdrive switch, and a TC lock up switch.
fourth, u will need to get a external regulator for the altenator. the 99 goes through the ecm, and since the stock tach will not work, it will read that the motor is not running and wont switch the alt. on. and u cant hook it up straight to the battery, or it will over charge the batterys.
i put a 2nd gen 12v in my 99 is how i know about some of these problems. mine is an auto, so i have a lock up switch and overdrive switch. the electronics is the hardest part to get working. if ya got any questions u would like me to go into detail about, p.m. me.
thanks for reading and good luck
Old Dec 22, 2009 | 05:43 PM
BIG RON's Avatar
thanks for that info, it is a manual tranny so that solves that, i will start the project, get a regulator,and se how it goes from there,and again many thanks to you all
Old Dec 23, 2009 | 11:42 PM
dealwithit's Avatar
good luck man could you possibly swap the 24v head onto the 12v block and keep all the electronic stuff?
Old Dec 24, 2009 | 08:22 AM
Try to keep the info in the thread, that way everyone can see it and maybe even learn something along the way
Old Dec 24, 2009 | 01:09 PM
the head isnt where all the electronical parts is the problem. if ur meaning to keep the vp on the truck, then u would have to swap the front cover, the pump, and all other sensors, but i still dont think it would run, because u wouldnt have the hole in the block for the crank sensor, which is where the 99 get there tach reading from.
Old Dec 24, 2009 | 05:46 PM
Tinman875's Avatar
Yep i put a 03 crate cummins into a 01 truck. dang block cracked. what a job that was. ended up buying a autometer diesel tach that reads off the alternator. crazy how that thing works. i did not get the cruise to work either, and i had a 6spd man. this guy is a plethora of info fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits he'll answer questions.
