LB7 PPe HOT +2 questions
Old Dec 19, 2009 | 12:28 AM
hotlb7's Avatar
Default LB7 PPe HOT +2 questions
Can you check balance rates? rev limiter up to 4k RPM? Can you set high idle with this programer? Can you check fuel rail PSI? Im thinking about buying it from a friend for $400 bucks . thanks
Old Dec 19, 2009 | 01:07 AM
2500HeavyDuty's Avatar
dont you have efi live?
Old Dec 19, 2009 | 08:08 PM
hotlb7's Avatar
yeah but i got rid of it cause the douche bag who tuned my truck, over preassureized my fuel rail and runin a couple of my aftermarket injectors . So im lookin at a PPe+2 cause i dont trust anyone tuning my truck.
Old Dec 20, 2009 | 06:57 AM
so you would rather go with a hand held that does not compensate for larger injectors...
i dont know if ppe does all of that, but you can call them and find out from them, they can also fix up the pp2+2 to compensate for the larger injectors so you don't over fuel and loose rail pressure because of it, cause ppe tuning is very aggressive.
you really have to have some very high RP to ruin injectors, much more than what a stock pump can put out
Old Dec 22, 2009 | 10:59 PM
hotlb7's Avatar
the injector hold down bracket wasnt torQed to spec. So the knock reAl bad and had lots of whte smoke. Ending up crackin a couple injector bodys. Im talking to a guy name NEWLY TOLF who owns Undergound diesel performance whos gonna give me a mild tune because i dont have a built tans. He is a LB7 guru, so he has my trust
Old Dec 22, 2009 | 11:26 PM
yeah i know of newly,he has a big purple motor too looks pretty sweet alot of work went into it, probably a 10 second truck if it doesn't have 24's and run up in the mountians, afiak he doesn't do tuning he has a guy who tunes his truck who goes by mike (MMLMM)
Guy tripp makes some billet injector hold down brackets that use studs to hold the bracket in.
Its good that ur staying with efi live, im sure mike can help you out with a trans safe tune.
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
01LB7Duramax
Wanted To Buy (WTB) - Used
Mar 3, 2015 08:04 PM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
