Urgent Help with Banks six gun and IQ!!
Old Dec 19, 2009 | 12:04 AM
megawagon's Avatar
Default Urgent Help with Banks six gun and IQ!!
Hey everyone, I just installed a banks six gun with the new iq on my 07 megacab long bed. I keep getting a error code on my IQ says "manifold absolute pressure (map) output voltage out of range". The truck feels damn slow and isn't itself...
Can anyone help diagnose this? anyone else experience this?
My truck has got stock electronics, but afe intercooler, ats aurora 3000 turbo, manifold, and intake plenum. along with a NAPD race tranny...
I am leaving for a 1500mile road trip tomorrow and need to get this figured out...I needs some guages on the trip (for hauling) and I procrastinated a bit..
Thanks!
Old Dec 19, 2009 | 12:09 AM
wildbill's Avatar
Your in limp mode on account of the code. Check the connection out, make sure no loose wires, then try and clear the code. If it clears, found the problem, if not, got an issue with the Banks harness. If that's the case, remove the Banks, and see if the code clears and stays dead.
Old Dec 19, 2009 | 12:14 AM
megawagon's Avatar
awesome thanks bill. So i checked the mainfold sensors an fuel pressure...It sounds like the truck could have another loose connection to make this problem? the manual says just to check the manifold sensor and try again (not much help)..
Thanks for the heads up on limp mode...hadn't thought of that...I will try all connections tomorrow and see if the problem persist..otherwise I am going back to my old programmer
Thanks
Old Dec 19, 2009 | 12:17 AM
wildbill's Avatar
IIRC, it's like the sensor isn't even plugged in.
Old Dec 19, 2009 | 11:14 AM
megawagon's Avatar
Update... Checked all connections and all is ok still getting same error code on the banks unit, I will pull off I guess and return to my old programmer... Anything else I should try?
Old Dec 19, 2009 | 11:23 AM
wildbill's Avatar
How old is the Banks unit??
Old Dec 19, 2009 | 11:28 AM
megawagon's Avatar
its brand new..
this unit
Banks Power Six-Gun Diesel Tuner w/ iQ-Dashboard PC
Old Dec 19, 2009 | 11:31 AM
wildbill's Avatar
Unplug just the MAP sensor connection, then clear and re read codes. If the code comes back, look at the connection on the truck.
Old Dec 20, 2009 | 12:10 AM
dangerous1965's Avatar
Crazy thought....... Are you plugged into the right connector??
Old Dec 20, 2009 | 12:19 AM
megawagon's Avatar
Yeah I check them all to make sure...I disconnected everything and left it in place until monday...Iwill call banks in the morning to find out more
Thanks!
