p-pump 24v questions
Old Dec 16, 2009 | 10:05 PM
Cumminsdieselboy's Avatar
Default p-pump 24v questions
ok a buddy of mine is wanting to do a p-pump swap and i am graced with the job. i got all the parts (a 12v donor engine). i know i gotta get injection lines and stuff, but what do i use for injectors? i was thinking about using stock injectors and putting lower pressure springs but we want a pretty good amount of fuel as this truck will be a drag/pulling truck.
Also any hints or tips would be greatly appreciated. we are doing this swap on an 01 engine, not in an 01 truck
thanks
Old Dec 16, 2009 | 11:37 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/5-9l-1...ight=pump+swap see if this will help you in your project
Old Dec 22, 2009 | 09:53 PM
Seems to clear up some things. i have heard that getting the timing set is the hardest part. i am also wondering what size injectors would be good for around 800hp. the p-pump is a 160 pump with lcdv's, 4kgsk, i am gonna run .120 lines with .093 connector tubes. i am wondering if i use stock 24v injectors for now if it will be ok or not. i will be running a single turbo until i get money to buy twins. i am studding the head and putting a .020" over head gasket in so i can run twins and advanced timing.
Any tips or trick are appreciated. thanks
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
moneypitk5
Feb 12, 2015 11:01 AM
