Vibration when letting of pedal
Old Dec 15, 2009 | 02:03 AM
JimmyT's Avatar
Default Vibration when letting of pedal
When i let off the acelerator im getting a vibration and it feels like its coming from under the truck. When i acelerate i dont feel it. I'm thinking bad U-Joints.
I have a 2004 4x4 dodge cummins 6spd 93,000miles
Old Dec 15, 2009 | 03:20 AM
97cummins's Avatar
I was also thinking u-joints.
Old Dec 15, 2009 | 07:27 AM
wildbill's Avatar
Jack up a rear wheel, the while looking at the joints, have someone run the wheel back and forth by hand.
Old Dec 23, 2009 | 12:49 PM
LOGANSTANFORTH's Avatar
Pinion bearing or loose yoke...Its vibrating when running on the coast side of the ring...
Old Dec 23, 2009 | 01:15 PM
94Matt's Avatar
Could also be the driveshaft carrier bearing if it has one, they will vibrate on decel usually.
Old Dec 23, 2009 | 04:07 PM
blkjack's Avatar
X2 on the pinion bearings. Check the u-joints pull the shaft and see if they are binding up and while its out check for play in the Pinion and jack the rear axle off the ground and spin the tires see if it sounds rough or anything.
Old Dec 24, 2009 | 03:43 PM
Hummin Cummins's Avatar
Another way to find a bad u-joint is to touch them. If one it hotter then their you go.
Old Dec 28, 2009 | 12:11 AM
JimmyT's Avatar
Thanks for all the good info fellas I had two bad U joints. one was binded and the other was loose.
Old Dec 28, 2009 | 12:15 AM
wildbill's Avatar
I reckon you installed greaseable joints??
Old Dec 29, 2009 | 07:42 PM
vince7723's Avatar
Check your front driveshaft going into the diff. Kinda felt it more when I let off too. I posted it in theis section, "weird vibration" check out my post, I hope it helps.
Jesser321
Oct 10, 2015 03:54 PM
weatherby
Aug 31, 2015 08:04 PM
Moly Squid
Mar 28, 2015 04:26 PM
krinderhagen
Dec 31, 2014 07:12 PM
findau1
Oct 28, 2014 03:47 PM
