NV4500 input shaft
Old Dec 14, 2009 | 03:21 PM
rmuns454's Avatar
Default NV4500 input shaft
I want to put a GM NV4500 behind a cummins 4bt. I am Looking to swap the GM for a Dodge input shaft. My trans had 90,000 miles on it with no issues so far. Is there a consern about the gear wear pattern (new input with the old countershaft gear) or would this not be an issue
Old Dec 14, 2009 | 03:37 PM
Jet A Fuel's Avatar
I have installed a new drive gear against an old gear and not had any trouble. The most it might do is be a little louder IMO.
Old Dec 14, 2009 | 04:18 PM
FastCR's Avatar
what year trans? It's gotta have the newer 1st gear ratio (5.something not 6.something). You will need input shaft, the input shaft bearing retainer plate thing, and I believe you do need to run the dodge bellhousing and throwout setup. Thats how I did mine.
Old Dec 14, 2009 | 07:29 PM
rmuns454's Avatar
ya its the newer 5.something first gear just wanted to make shure i wont ruin the gear box like if you swap and axle ring or pinion with out replaceng the set
Old Dec 15, 2009 | 12:28 PM
FastCR's Avatar
my trans has about 100k on it and I put a new input in it and everything is looking good so far, I inspect it every couple thousand miles.
Old Dec 15, 2009 | 04:08 PM
Diesel Nut's Avatar
I have a brand new input shaft.
Old Dec 15, 2009 | 10:23 PM
rmuns454's Avatar
So if i go with a dodge input and dodge bellhousing clutch ect. The 6bt flywheel will bolt up the the 4bt crank. Are the flywheels balanced the same for the 4bt and the 6bt. Or is this not an issue to worry about
taweste
Sep 10, 2015 09:16 PM
klu408
Price Quote - Request A Price
Apr 26, 2015 07:28 PM
CumminsMan2.0
Dec 11, 2014 04:57 AM
woodsman27
Dec 9, 2014 09:55 AM
GreenDieselF
Nov 9, 2014 07:18 PM
