fuel pressure
Old Dec 11, 2009 | 07:34 PM
Sawman's Avatar
Default fuel pressure
how much fuel pressure should a lift pump have on 86 model 6.9
Old Dec 11, 2009 | 08:54 PM
ArizonaRedneck's Avatar
Ford diesel 6.9 7.3 IDI i read some info from this site and said 60 to 120 psi thought you might like it to check it out for yourself good luck and hope its the info you need
Old Dec 12, 2009 | 12:57 AM
Sycostang67's Avatar
There tends to be a bit of confusion reagrding pumps on these trucks. When you say lift pump, I think of the fuel pump on the side of the block which only puts out about 5psi. The injection pump on top of the motor that is fed by the lift pump puts out more, most likely the numbers mentioned above.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
