ford 7.3 diesel powerstroke blowing fuses
Old Dec 10, 2009 | 07:41 PM
Jim919's Avatar
Default ford 7.3 diesel powerstroke blowing fuses
I went to start my truck this morning and it wouldn't start. I had it plugged in all night, so i threw a charger to the battery. I set it to 200 amp quick start, got in truck and started it. I went in the house came back out found truck had stopped running. Went to restart the truck and found that I had no wait to start light. I checked the fuses in the power distribution box under the hood, found that i had blown a 30 amp glow plug controller fuse. I replaced the fuse and turned the igniton on. The fuse blew instantly. I think I cooked wires, if so where should I start looking? Or maybe some suggestions on this problem. Any help would be appreciated!
Old Dec 10, 2009 | 08:45 PM
99stackedpowerstroke's Avatar
it might be your glow plug sylenoid on top of the motor right behind and to the passenger side of the fuel filter bowl it will look just like a reg battery sylenoid right there its not hard to see.
Old Dec 10, 2009 | 10:44 PM
Superstroker10's Avatar
is that circuit tied into anything else? i know the fuel bowl heater circuit shares fuse with the idm. found that out the hard way when my fuel bowl heater shorted out
Old Dec 11, 2009 | 06:00 PM
Jim919's Avatar
ok thanks I will check that!
Old Dec 12, 2009 | 12:58 PM
the fuel bowl heater is the number 30 fuse in the cab not under the hood
Old Dec 13, 2009 | 12:11 PM
yeehaw's Avatar
yep just had that on thursday night, just unplug it and replace the fuse
Old Dec 13, 2009 | 12:19 PM
a new fuel heater is 150 plus taxes u can prob get on at the junk yard for round 20 bucks my cousins 99 350 did that two weeks ago and we got one from a junk yard and it works just fine
Old Dec 13, 2009 | 01:48 PM
DieselDanBoy's Avatar
glow plug relay is probably more than shot, you havn't replaced it yet have you?
Old Dec 15, 2009 | 11:18 PM
wildbill's Avatar
Updates??
Old Dec 19, 2009 | 01:38 AM
wildbill's Avatar
Please update.
