1993 Dodge Ram 5.9 wont start
Old Dec 9, 2009 | 02:07 PM
Randy4541's Avatar
Default 1993 Dodge Ram 5.9 wont start
Can somebody please help me took fuel injection pump out to fix a leak put the pump back on. Cant get the truck started. I got all the air out the fuel lines and will not stay on .Spray a little starting fluid turns on but will not stay on Can somebody Please Help me out Thank You. Randy God Bless
Old Dec 9, 2009 | 02:14 PM
wildbill's Avatar
Sounds like you still got air trapped, though you got some fuel, cause a diesel won't run on straight either. Keep cracking injector lines.
Old Dec 9, 2009 | 02:18 PM
Randy4541's Avatar
I crancked injectors for about an Hour. And got good preassure . but will not stay Running
Old Dec 9, 2009 | 02:20 PM
wildbill's Avatar
Check the fuel shutoff. I bet it's not opening all the way.
Old Dec 9, 2009 | 02:24 PM
Randy4541's Avatar
Sorry for all the silly questions im new at this Wildbill can u tell me were the fuel shut of is located and how do i ckeck it Please. THANK YOU
Old Dec 9, 2009 | 02:49 PM
wildbill's Avatar
It's on the side of the injection pump, which is on the drivers side of the engine.
Old Dec 9, 2009 | 03:21 PM
Randy4541's Avatar
Thank You Wildbill
Old Dec 9, 2009 | 03:49 PM
Budgreen's Avatar
throttle index?
idle adjustment?
Old Dec 10, 2009 | 04:55 PM
Randy4541's Avatar
Hi guys here is an update the truck still wont start i work on it all day today i talk to the person who i got the truck from this truck was sitting for 3 years with out starting they told me that the reason they park the tRuck. It had a fuel leak on th back of the fuel injection pump they took it out took the back of the injection pump out put a new seal on put it back on the truck but never got it to start again . i put the timing on the pump tinking that was the problem but did not start. Can somebody please help me PLEASE THANK YOU
Old Dec 10, 2009 | 05:19 PM
mfolsomblueD's Avatar
Check to see bout water in the fuel filter
