7.3 Leaking Diesel
Old Dec 8, 2009 | 04:04 PM
Yanez's Avatar
Default 7.3 Leaking Diesel
Alright, I have a 1999 7.3 PSD and I got a dripping leak, haven't really took a close look at it but I thought I'd post it on here and get some ideas where to start looking. I'm not sure if it is directly related but it was 10 degrees here lastnight and the high isn't above freezing for the past couple days. Any help would be appreciated. Thanks fellow bombers.
Old Dec 8, 2009 | 04:43 PM
7.3 Cowboy's Avatar
look at at your feul bowl
Old Dec 9, 2009 | 12:21 PM
wildbill's Avatar
What he said.
Old Dec 9, 2009 | 12:38 PM
wildbill's Avatar
Old Dec 9, 2009 | 08:43 PM
Yanez's Avatar
I'm working the shift where I get to see the sun come up and go down so It's going to be Sunday before I can dig in and have a look.
Old Dec 9, 2009 | 09:04 PM
Casefarmer's Avatar
ok i have/had the same problem on my 97. there is a lift pump that runs off the camshafts and that could have a pee hole in it and its 115.14 through napa but i have a farm discount so it might be cheaper but i not sure. also there is a regulator on the driver side of the fuel filter housing and the sensor is half metal and half plastic and the plastic starts leaking next to the metal, idk how much that is. if the lift pump is the problem its a 3-5 hr job took me 4 1/2.
if you have anymore questions pm wit your num and ill call you and give you more info. the step by step process is a damn book or i would tell you how
Old Dec 11, 2009 | 10:33 PM
wildbill's Avatar
Please update.
Old Dec 15, 2009 | 11:03 PM
wildbill's Avatar
Going to close the thread for now. Can reopen and update.
Excursion73
Sep 17, 2015 11:46 PM
Excursion73
Ford Excursion 99-05 7.3L and 6.0L
Aug 29, 2015 05:52 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
KimberlysTruck
Mar 5, 2015 06:28 PM
krinderhagen
Dec 31, 2014 07:12 PM
