98 Jetta AHU Problem Code 0575
Old Dec 7, 2009 | 06:08 PM
firewire300's Avatar
Unhappy 98 Jetta AHU Problem Code 0575
I am looking for some assistance with my 1998 Jetta AHU 1.9L TDI. I have a re-occurring 0575 pressure code. Where should I start the troubleshooting?
I have cleaned the intake manifold and egr valve once (on vehicle) and it helped but the problem is persisting. I have cleaned the airbox and Intake screen, installed a new airfilter with only marginal results. Obviously when it is warm outside and the vehicle is working the problem is worse, end up in LIMP mode and no power. Can almost get through the fridgid cold winter without it happening et all.
I have a transducer for my Fluke 88 and was going to check the turbo boost pressure.
I have the factory Bentley Manual but it is all but useless for this problem. Any help with a break down of troubleshooting would be appreciated. Simplest to indepth in order would be appreciated.
Also looking for any information on the EGR system and how it functions ie: at what RPM it dumps at etc.
I don't want to try and "re-invent the wheel", I am sure you guru's have covered this ground before.
TNX in Advance
firewire300
Old Dec 7, 2009 | 06:32 PM
wildbill's Avatar
Don't much of anything about VW, but someone will chime in. Subscribe to this thread, that way your notified when someone posts. Just click on thread tools (just above and to the right of your post) and click on subscribe to this thread.
Old Dec 8, 2009 | 01:41 AM
AHolt's Avatar
Go to the VW TDI forum and they can help you.
Old Dec 9, 2009 | 12:17 PM
wildbill's Avatar
Updates??
Old Dec 11, 2009 | 10:30 PM
wildbill's Avatar
Please update.
Old Dec 15, 2009 | 11:02 PM
wildbill's Avatar
Going to close the thread for now. Can reopen and update.
burndiesel
10
Feb 7, 2023 01:15 AM
flash7210
Jul 5, 2015 09:25 AM
