No Running Lights or Dash Lights!!! Help!
Old Dec 7, 2009 | 04:27 PM
nelkcots's Avatar
Default No Running Lights or Dash Lights!!! Help!
OK so the other day I got in my truck and started it up and the dash lights went out. Not thinking anything of it and assuming it was a fuse I wasn't worried about it. I got pulled over a few miles later because I had no running lights on the rear of my truck. Now I've started thinking about it and trying to figure out what it could be. I don't have a right brake light, right rear turn signal, any running lights what so ever(including above cab lights marker lights and liscense plate) and no dash lights. I checked all the fuses and none are blown. Any ideas on what it could be? The truck is a 99 f350 crew cab 8 foot bed DRW.
Thanks for the help in advance!
Old Dec 17, 2009 | 10:37 PM
nelkcots's Avatar
bump.. still cant figure this out guys
Old Dec 17, 2009 | 10:48 PM
wildbill's Avatar
I bet it's your head light switch. If you can find a good used one, try it. No go, might be a ground issue.
Old Dec 17, 2009 | 10:54 PM
ArizonaRedneck's Avatar
brake light turn signal through me off did they work before and have you checked your headlight switch because if iam correct they are on two different circuits make sure switch is good
Old Dec 18, 2009 | 05:04 PM
dirty balz's Avatar
i had to do this to my truck. headlight switch from ford is like 100-200 if im not mistaken
Old Dec 22, 2009 | 11:23 AM
PowerStrokin's Avatar
Did you figure out what it was? My truck just did the same thing. Now I dont have any dash lights or running lights. It worked fine last night now it doesnt.
Old Dec 16, 2015 | 05:36 PM
jimrd's Avatar
I have the same problem
I changed the 15 amp fuse under the dash and it blew right away
I have a dead short some where in the light circuit ...
any body got a good idea where to start and find a dead short in this circuit
with out keep blowing fuses
thanks
jim
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
