Torque converter / valve body issues
Old Dec 6, 2009 | 10:09 AM
chadillac's Avatar
Default Torque converter / valve body issues
What can i do with just these two up grades versus full rebuild.I have the money saved for a full rebuild and all the other goodies.But can not make up my mind.I have 41 on the tranny and did the filter change and flush.But i know i have to upgrade to run more power.I don't tow anything over5k.But i sure do like to lean on it.
Old Dec 6, 2009 | 10:28 AM
Shea@L&N Performance's Avatar
FormerVendor
If all your internals are in good shape then a tc and a vb will work just fine. Still wouldnt recommend any boosted launches anything like that
Old Dec 6, 2009 | 03:05 PM
Like Shea said no boosted launchs on stock shafts. You could do a VB, TC and Billet Input.
Old Dec 29, 2009 | 10:56 PM
Diesel Nut's Avatar
A quality VB and good converter is a great upgrade. If you like to lean on it then a billet input is in your future. Here is the issue. The billet input requires about 1/3 of the transmission to be torn down and reassembled. The transmission is already out! If you are at that point, then build it right the first time.
Old Dec 30, 2009 | 06:34 PM
RHill's Avatar
On a full rebuild they can fix the crapy oil ports to the overdrive.
Old Dec 30, 2009 | 07:17 PM
busta's Avatar
X2
Old Dec 31, 2009 | 03:41 PM
chadillac's Avatar
How can i fix the oil ports to the overdrive?
Old Jan 1, 2010 | 06:38 PM
sparkey's Avatar
Hey, for what it's worth, do it right while the trans is out; it'll save you money in the long run!
Da Bomb
Sep 3, 2015 10:00 AM
jeremiah1
Jul 21, 2015 06:35 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
Tmaxxrox97
10
Nov 10, 2014 10:37 PM
