Turbo flange
Old Dec 1, 2009 | 11:12 PM
Biggsw784's Avatar
Default Turbo flange
Curious of what type of turbo flange so on this 6.5s?? I am wanting to change the turbo out for something with some sound, so alittle large turbo. Thanks for any help.
Old Dec 2, 2009 | 04:40 AM
12vcummins96's Avatar
base or exhuast
Old Dec 2, 2009 | 07:38 AM
Biggsw784's Avatar
Just the base. I want to use the same exhaust manifold. i can make everything else work. Thanks
Old Dec 2, 2009 | 01:55 PM
Woody35's Avatar
ill measure it tonight since i got the turbo off. a good turbo would be the A Team Turbo
Old Dec 4, 2009 | 06:34 PM
Woody35's Avatar
its roughly 4 inch by 2.5 inch. i think its a T3 flange but not sure
Old Dec 5, 2009 | 01:12 PM
Biggsw784's Avatar
ok thanks man
The pump has been turned up and has full exhaust and a cold air kit but you cant hear the turbo. The turbo is the factory gm3 and I know its small but was curious if there is a different turbine wheel I can put in or what options I have to make it whine??
Old Dec 5, 2009 | 03:23 PM
its a t3
Old Dec 6, 2009 | 01:36 AM
Woody35's Avatar
no options for a turbine wheel. a good turbo would be an A Team Turbo. it doesnt whine but it decreases backpressure so you get a lot more performance. how much boost are you running with the GM3
Old Dec 6, 2009 | 03:35 AM
dealwithit's Avatar
hmmm i wonder if your having wastegate issues if your not hearing the turbo? my truck is completely stock and i can hear it inside the cab when i hammer on it.
Old Dec 6, 2009 | 04:11 PM
Biggsw784's Avatar
i wired the wastegate shut, and it runs up to about 10 psi.
i dont know man. i have the wastegate shut.
