turbo on 12 v cummins
Old Nov 28, 2009 | 08:48 PM
streetrod's Avatar
Default turbo on 12 v cummins
i have a 97 12v turbo from a stick sitting on my shelf and have ben informed that it is larger than the turbo on mr 95 12v with an auto is this correct. if so do you know how much mor boost it will have do i need t update my injectors
Old Nov 28, 2009 | 08:52 PM
wildbill's Avatar
The autos were HY35 (faster spool up, but ran less CFM) than the HX35, which they ran on the manuals.
Old Nov 28, 2009 | 08:53 PM
12vcummins96's Avatar
it will produce 19psi stock maybe 20 there is no need for bigger sticks
Old Nov 28, 2009 | 08:57 PM
Whit's Avatar
Site Mascot
you will loose a bit of snappyness on low RPM but will gain more CFM in higher RPM to lower EGT............excellent for towing
Old Nov 28, 2009 | 09:05 PM
streetrod's Avatar
ok that answers my question no need to change turbos thanks for the advice
Old Nov 28, 2009 | 10:37 PM
wildbill's Avatar
Am going to close the thread and if need be, can reopen.
huntman7
Sep 27, 2015 10:41 AM
huntman7
8
Aug 28, 2015 05:42 PM
jd_clampit18
Feb 11, 2015 04:44 PM
Jan 28, 2015 03:30 AM
Oct 24, 2014 04:40 AM
